tiweintraub's avatar
tiweintraub
Follower
Dec 23, 2020
Disable SIP ALG on CM500
Hello:  I am trying to disable SIP ALG on my CM500-100NAS Cable Modem.  I am arunning v1.01.14 Firmware.  Under the advanced tab, I don't have the options to go to SETUP-WAN SETUP and disable SIP.  What am I missing here?  I am using Comcast/Xfinity as an internet provider.  Is this something that Comcast needs to turn off?  Thanks for the advice.
1 Reply
  • plemans's avatar
    What you're missing?
    The CM500 is a modem only. It isn't a router.
    There's no disabling it on a modem.
    Maybe on a modem/router combo device but not strictly a modem.
