Njallen41
Oct 02, 2021Initiate
Do not buy Nighthawk c7000v2
WiFi speeds are not what is advertised (up to 960 Mbps). I’ve seen multiple threads on this site with folks having the same issue. All “troubleshooters” on other threads blame the user and not the fal...
Njallen41
Oct 03, 2021Initiate
Thanks “super user” for your help and not being condescending at all. It’s always great to hear from an “expert.”
Technical Specifications:
AC1900 (600Mbps @2.4Ghz with QAM support +1300 Mbps 5Ghz 11ac)
I am now getting 800Mbps on WiFi from my now rented xfinity modem/router. I guess I’m living in the future and getting speeds that are impossible according to the “super user.”
Oct 03, 2021Guru - Experienced User
Those are connection rates only between the modem and wifi devices only. Not actual speed thru put thru the system.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
You don't have to take my word for it though.
Good Luck.
