HodaS
Jul 17, 2017NETGEAR Employee Retired
Does a CM600-1AZNAS (24*8) DOCSIS 3.0 Cable Modem, Certified for XFINITY work with other providers?
Hi, I am considering purchasing a CM600-1AZNAS (24*8) DOCSIS 3.0 Cable Modem, Certified for XFINITY. But I want to know if it works with other providers (such as comcast, time warner cable, charter,...
- Jul 17, 2017
It is exactly same product with some possible minor packaging changes.
HodaS
Thanks for getting back to me.
The issue is that there are two types of CM600 on Amazon, One that is indicated to be certified by XFINITY by Comcast, Time Warner Cable, Cox, Charter & more: https://www.amazon.com/NETGEAR-download-960Mbps-Certified-XFINITY/dp/B01621M1S4/ref=sr_1_1?ie=UTF8&qid=1500330791&sr=8-1&keywords=netgear+cm600
and one that just says certified by XFINITY: https://www.amazon.com/Netgear-CM600-1AZNAS-download-960Mbps-Certified/dp/B06XGZBCKP/ref=sr_1_4?ie=UTF8&qid=1500330791&sr=8-4&keywords=netgear+cm600
I wonder if the second one is compatible with other providers.
vkdelta
