Leslied2's avatar
Leslied2
Does my firmware update automatically when I reboot?
I've tried everything in the Genie desktop and the iPhone Nighthawk apps to update my firmware. I'm not that far behind but my streaming cuts out every night and I think it's a firmware issue.
Anyway, I'm able to reboot. Does that reboot update the firmware? If not, where is the button for updating firmware? I can't find it anywhere. Online it says it's under Admin but I don't see it there. I can find the Firmware section but no way to update.
  • plemans's avatar
    You have the C6250?
    If so, its a modem/router combo device and the firmware is built into the provisioning from the ISP. Its not user updatable.
    https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
    https://www.netgear.com/support/product/C6250.aspx
    A few more details on your issue might help.
    1. does it happen at the same time each night?
    2. does it happen on all devices or just one?
    3. do wired devices have issues or just wireless?
    4. if its just during streaming, are your streaming devices on the 5ghz when streaming?
    5. what speeds do you pay for?
    6. what speed do you get on/at the devices having issues?
    7. got a screen snip of the cable connections page and event logs.
    • Leslied2's avatar
      Leslied2
      Wow, this is incredibly thorough and helpful. Thank you!
      According to the chart in the link I have the latest firmware.
      At first I thought it did but I'm not positive. I'll make note and see and get back to you.
      It's never happened on my desktop or phone - just my Roku tv.
      The Roku tv is wired. At first I thought it was just incompatible with HBO, for example, as I've read online there are issues there. But it is happening on Netflix and other streaming channels, too, now.
      I don't know where to specify that the tv connects through 5ghz.
      As of yesterday it was 100 gb(s or is it h?) but I just changed to 600. Do you think this will help?
      I don't know how to measure that on a tv/roku so I'm not sure.
      I will grab that next time I get the issue, along with the times of days.
      Again, so many thanks for your consideration!!! I'm hoping the reboot will help but I suspect that's wishful thinking.
      • plemans's avatar
        You should be able to do a network test on the roku to test speeds.
        In terms of your speeds, it isn't worth it on that C6250 to upgrade to 600mbps. I don't believe comcast or any other ISP certifies it for anywhere close to those speeds. You'd have to check with the ISP on that but I believe its only up to 200mbps on comcast.
        See what the cable connections page looks like.
        And test a hardwired speedtest on the modem to see what you get wired into it with a pc/laptop
