KevinC123
Jan 03, 2022Aspirant
Does the CM1000v2 cable modem have a firewall?
When I scan two specific ports from outside my home they show as blocked. nmap -Pn -T4 -p 25,9000 "IP address" Starting Nmap 6.40 ( http://nmap.org ) at 2022-01-03 16:54 UTC Nmap scan report fo...
- Jan 03, 2022
CM series modems are modems only. No built in router or firelwall. If you have the CM series modem, you'll need to connect a external wifi router to the modem then configure as needed. Most current router firewall are all automatic with little or no user configurations needed.
If you need a actual firewall applicance device, then you need to connect a firewall device. Do a search as there are many. Sorry, I can't recommend anything.
Jan 03, 2022Guru - Experienced User
KevinC123
I suspected that the CM1000v2 modem wasn't blocking traffic. I also have a R6400v2 router, which is connected to the LAN port of the modem. I need to forward two ports to a couple machines, and I know how to do that. It looks like traffic on those ports isn't even reaching the router. My conjecture is that the traffic is blocked by my ISP. They told me I needed to contact Netgear to make sure their products are set up right. I'm pretty sure everything is OK. But, I'm trying to make sure with experts like you.
Thanks FURRYe38!
- FURRYe38Jan 03, 2022Guru - Experienced User
Ya, once you have the router set you'll should be good.
Enjoy. 📡
