KevinC123
Jan 03, 2022Aspirant
Does the CM1000v2 cable modem have a firewall?
When I scan two specific ports from outside my home they show as blocked. nmap -Pn -T4 -p 25,9000 "IP address" Starting Nmap 6.40 ( http://nmap.org ) at 2022-01-03 16:54 UTC Nmap scan report fo...
- Jan 03, 2022
CM series modems are modems only. No built in router or firelwall. If you have the CM series modem, you'll need to connect a external wifi router to the modem then configure as needed. Most current router firewall are all automatic with little or no user configurations needed.
If you need a actual firewall applicance device, then you need to connect a firewall device. Do a search as there are many. Sorry, I can't recommend anything.
Jan 03, 2022Guru - Experienced User
Possible. Might try "R6400 port foward configuration" as a title and post.
Remove the firewall data also...
For your R6400, please post in this forum:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you.
