vwwanted
Mar 30, 2016Aspirant
DoS attack, Teardrop or derivative, Ping of Death, strange non-DHCP IP address connected to wifi
I'm getting lots of Dos attacks logged in my C3000 modem/router. They appear to be coming from inside my network, from my wifi. I keep seeing a device attached to my wifi with an IP address of 1.1.15...
jandawood
Nov 02, 2017Aspirant
We have a C3700 router and I've noticed that a lot of times during ther day my wifi connection stops working. I turned wifi of and back on for affected devices and it works for about 15 minutes before it reapears.
I just checked the logs and found multiple DOS attack messages (Tear Drop and Ping of Death).
From everything i've read, it seems like its a known issue with NetGear. I guess I will do better research for my next router.
- SamirDNov 02, 2017Prodigy
If you can turn off the wifi and it fixes the problem, you can just get a access point and connect it to the netgear.
- Bob94301Dec 05, 2017Guide
I have the same problem with a C7000. Very tired of it. Of course, its an iPhone changing into an IP address in Austin, Texas and bombing DDoS attacks on everything from the Department of Defense to Bejieng.
Question is, I have high speed Comcast. Does anyone know if any Arris modem will handle 300 MBPS and show the connected devices by MAC and IP address AND show logs for attacks? Their manuals are terrible. I want to abandon Netgear, but not if another brand has the same issue and worse yet, cannot show it to youi.
Appreciate your input.
~Bob
- PGillardDec 05, 2017Guide
gave up and bought a motorola mg7550 . Instant fix. easy to set up and control.
Will never buy netgear again. tech support in non existant. Have had bad experiences with there switches also.
