vwwanted
Mar 30, 2016Aspirant
DoS attack, Teardrop or derivative, Ping of Death, strange non-DHCP IP address connected to wifi
I'm getting lots of Dos attacks logged in my C3000 modem/router. They appear to be coming from inside my network, from my wifi. I keep seeing a device attached to my wifi with an IP address of 1.1.15...
JollyRoger72
Jan 12, 2018Guide
update:
I turned off the Router Mode on the c3000 and it rebooted itself. I added the Linksys N750 via the CD it came with and the setup could not have been easier. My speeds are amazing now! Regularly getting 115mbs upload speeds vs the 30 I was getting when i was just using the c3000 for both modem and router. no more conflicts with iphones and randomly assigned IPs.
Left4Dead2
Jan 13, 2018Guide
JollyRoger72 (Tutor),
Nice! Its something...wish I could have tried that while I had the C7000, but unfortunately after a frustrating time with support being bounced from one to the other even to L2, and they were asking to gather some more information? I said, "Forget it!" I even had Comcast come out to the home to check the interface and lines, at no charge since I was bounced to their support and go no where either...hence the courtesy check. Funny enough, the tech had made a reference to what you were saying, but I didn't consider to go into it any further do to all the conversations we were having. I do still have my old C3000 though and a couple of other gateways too...may have to give that a try. Ultimately, I will probably end up getting a different modem altogether. Thanks for the reply and hope that works out for you long term, I would be interested in finding out down the road.
