vwwanted
Mar 30, 2016Aspirant
DoS attack, Teardrop or derivative, Ping of Death, strange non-DHCP IP address connected to wifi
I'm getting lots of Dos attacks logged in my C3000 modem/router. They appear to be coming from inside my network, from my wifi. I keep seeing a device attached to my wifi with an IP address of 1.1.15...
LBermann
Sep 19, 2018Aspirant
I wanted to thank member ccunni3812 for the post tited "DoS attack and random ip addresses for iPhone"
I was having a similar problem with my IPad. As soon as my IPad was connected to my WiFI, I received DOS attacks - teardrop and SYN Flood. I had wiped my IPAD several times but it still came back. Finally I figured out a few things.
I have my Apple device backed up and may have inadvertently backed up the "bug". So everytime I download my backup, I got the bug again. I think I saved the bad website in my favorites. Since the DDOS attacks only happened when the wifi was turned on in my IPAD, I did the following:
- Changed the admin password on my router (yes I know, rookie move to not have done it in the first place).
- Turned on Access Control
- Deleted all unnecessary websites saved in my favorites on my IPad.
- Under Wan Setup, added the check mark to Disable port scan and Dos Protection from the router.
- Watched my logs
I will continue to watch my logs on a regular basis to make sure the steps taken above continue to work. Honestly, I am just so happy to have my IPad back.
