vwwanted
Mar 30, 2016Aspirant
DoS attack, Teardrop or derivative, Ping of Death, strange non-DHCP IP address connected to wifi
I'm getting lots of Dos attacks logged in my C3000 modem/router. They appear to be coming from inside my network, from my wifi. I keep seeing a device attached to my wifi with an IP address of 1.1.15...
Runemaster
Jul 04, 2019Aspirant
Here is the best fix....
1. Make sure firmware is fully up to date.
2. Keep the box checked for the dos and port scan protection setting. I played with this setting...you definitely want this checked.
3. Enable the guest band, put a strong password on it and make sure you leave the box that states something along the lines of " can access local resources and see other devices on network" unchecked
4. Put troubled devices on that guest network
5. Put new strong passwords on your router login, your 2.4 and 5 ghz regular or non guest ssid bands.
*** Strong password is 10 characters or more with upper and lower case numbers and special characters...
"Knowledge is power my friends"
"May the powershell be with you"
fduate
Jul 04, 2019Initiate
Comcast Xfinity is responsible for updating latest software, option is not possible for consumers. Also Netgear does not recommend checking box for DOS.
