wifi99
Aug 14, 2016Aspirant
DOS Attacks - Cause Router to Reset
My modem/router(firmware version is V2.02.08 and model is N600(C3700-100NAS)) randomly resets when it gets pinged with various DOS attacks like
'DoS attack: Ping Of Death'
'DoS attack: Teardr...
VE6CGX
Aug 14, 2016Master
You should enable DoS attack blocking from your router firewall.
wifi99
Aug 15, 2016Aspirant
Ok, I've unchecked the 'Disable Port Scan and DoS Protection' box on the setup page. Factory settings defaulted this to being checked - why?
- wifi99Aug 15, 2016Aspirant
After unchecking 'Disable Port Scan and DoS Protection', I'm now I'm seeing this in the logs 'DoS attack: TCP- or UDP-based Port Scan'. Again the source and target ip addresses are non-US various countries.
It hasn't caused a reboot yet but what is this? My ISP is Time Warner.
- DarrenMAug 17, 2016Sr. NETGEAR Moderator
Hello wifi99
Have you given your IP address out to anyone or do you run some type of server in your home that people connect to? You may want to talk to TWC internet support to try and get you a New Ip address or leave your modem unplugged for a day or 2 if possible so it assigns a new ip address to the modem.
DarrenM
