KTaltos
Apr 03, 2017Follower
DoS ICMP flood on C6300
I have received numerous DoS ICMP Flood attacks through my C6300 Cable Modem each day that cause either slowness or cause my router to restart. I have tried changing passwords, SSID Name, factory resets. Comcast has suggested that to fix the problem I would need to replace the modem. The attacks are coming from 168.1.128.51, 192.172.226.137, 27.151.115.81, 46.234.125.89, 185.94.111.1, 120.34.213.64, 104.207.145.43, 129.82.138.44, 195.251.255.69, 203.178.148.19, 206.117.25.90 and 36.85.204.239. Those are the IP's I've pulled from the logs in a day and a half of looking. My firmware version is V2.01.18 and the option under the Advanced tab, under the setup menu item labeled "Disable Port Scan and DoS Protection" is unchecked. Im not sure why, with this option enabled I would still be prey to these. Is there a way to secure the modem?
- DarrenMSr. NETGEAR Moderator
Hello KTaltos
I would try to check dos protection see if those dos attacks stop.
DarrenM
- TylorBlakeAspirantI have the same exact issue with the same ip addresses. Did you ever fix this and how if so?
- marescoAspirant
no and yes, i was tired to wait from any answer from netgear, i make the modem work on a bridge mode and buy a Netgate SG-1000 appliance firewall that runs pfsense and works like a router / firewall, and I add a switch, it solve all my issues
shame that Netgear do not backup their products
- TylorBlakeAspirantOk, Thank you for your help. Really appreciate it.
