Xealkry's avatar
Xealkry
Follower
Nov 18, 2017
Double NAT issue caused by ISP, with R6100 gateway
1 Reply
  • > [...] I've called my ISP and they've confirmed they're running a NAT
    > before my gateway (Netgear R6100). My gateway is also running NAT, so
    > I'm being double-NATed. [...]
       With my weak psychic powers, I can't identify your "my ISP" or the
    equipment to which your R6100 is connected.  When having two cascaded
    routers is the problem, the usual solution is to make one of them not be
    a router.  In some cases, the ISP gizmo can be put into a bridge mode.
    Alternatively, the R6100 can be configured as a wireless access point.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual, and look for "Wireless Access
    Point" (page 85).
       Which of these two solutions is better may depend on which device you
    can control, and which router has more/better desirable features.
