master_ravi's avatar
Feb 25, 2023
download light keep blinking, no internet cax80
including log
Time Priority Description
Sat Feb 25 07:08:05 2023 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:08:04 2023 Warning (5) Dynamic Range Window violation
Sat Feb 25 07:08:04 2023 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:08:03 2023 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:56 2023 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:56 2023 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:55 2023 Notice (6) TLV-11 - unrecognized OID;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:40 2023 Notice (6) Honoring MDD; IP provisioning mode = IPv6
Sat Feb 25 07:07:37 2023 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:19 2023 Critical (3) SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:17 2023 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:16 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:07:15 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:06:57 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:06:56 2023 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:05:53 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:05:53 2023 Warning (5) MDD message timeout;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:05:47 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:05:47 2023 Warning (5) MDD message timeout;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:05:44 2023 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 07:05:41 2023 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 01:17:56 2023 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 25 01:17:31 2023 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
  • michaelkenward's avatar
    michaelkenward
    Much as the logs can be useful, it helps to have a description of what is going on. Your subject is thin on details.
    Which is the "download light". I can't recall any LEDs with that label.
    Do you mean the Upstream/Downstream LEDs?
    Many of the LEDs – Internet, WiFi, LAN – blink when there is traffic.
    The CAX80 is a cable modem/router. What dies your ISP say? Those logs look like a connection problem.
    There are some serious experts on cable modems around here. While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Cable Modems & Routers
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • master_ravi's avatar
      master_ravi
      Guide
      I meant Downstream LEDs keep blinking
      TimePriorityDescriptionSat Feb 25 07:08:05 2023Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:08:04 2023Warning (5)Dynamic Range Window violationSat Feb 25 07:08:04 2023Warning (5)RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:08:04 2023Warning (5)Dynamic Range Window violationSat Feb 25 07:08:04 2023Warning (5)RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:08:03 2023Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:56 2023Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:56 2023Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:55 2023Notice (6)TLV-11 - unrecognized OID;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:40 2023Notice (6)Honoring MDD; IP provisioning mode = IPv6Sat Feb 25 07:07:37 2023Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:19 2023Critical (3)SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:17 2023Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:16 2023Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:07:15 2023Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:06:57 2023Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:06:56 2023Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:05:53 2023Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:05:53 2023Warning (5)MDD message timeout;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:05:47 2023Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:05:47 2023Warning (5)MDD message timeout;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:05:44 2023Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 07:05:41 2023Notice (6)CM-STATUS message sent. Event Type Code: 20; Chan ID: 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 01:17:56 2023Notice (6)CM-STATUS message sent. Event Type Code: 22; Chan ID: 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;Sat Feb 25 01:17:31 2023Notice (6)CM-STATUS message sent. Event Type Code: 20; Chan ID: 48; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:18:65:cb:3c:43;CMTS-MAC=00:01:5c:6b:f0:49;CM-QOS=1.1;CM-VER=3.1;
        michaelkenward
        What does the Internet service provider say?
        You'll need a cable expert to help out here. With luck one will be along soon.
