TheWolverine97
Nov 04, 2020Follower
Downstream light, Upstream light, and Online light
My Downstream light keeps blinking, my upstream light is off and my online light is off as well. I have disabled my AT&T WiFi so the signal are not competing with each other. I have also did a system reset as well. Both my Nighthawk AX8 WiFi Cable Modem Router, Model CAX80 and AT&T Modem Router are both brand new. Any ideas??
TheWolverine97 wrote:My Downstream light keeps blinking, my upstream light is off and my online light is off as well. I have disabled my AT&T WiFi so the signal are not competing with each other. I have also did a system reset as well. Both my Nighthawk AX8 WiFi Cable Modem Router, Model CAX80 and AT&T Modem Router are both brand new. Any ideas??
You have the CAX80 and a AT&T modem router?
I wasn't aware the cax80 was compatible with att service.
What ISP do you have and whatt is your full setup?
- Sorensen_kkAspirantOnce the modem syncs on a downstream channel, the Downstream light will go solid green and the Upstream light will start blinking green. The Upstream light will go solid green once it has established a connection. Depending on your service, additional channels may bond together.
Sorensen_kk Not sure if you're thread jumping and wanting help or if you're trying to help.
