somethingcleve5
Mar 24, 2016Aspirant
Dropping Connection Multiple Times a Day -- Do not purchase
I have browsed multiple topics and see this is a recurring theme. I have the c3700 in my home and another home. In both it crashes multiple times a day. It then reboots and works fine until it crashes and reboots. This happens at least 10 times a day. It is not the cable as my old modem and router work fine in both homes. It is not on a splitter. It is the netgear router. I have not seen an answer to this problem in any of the discussion topics. Do not purchase this router/modem combo unless you want the aggravation of waiting for it to reboot every half hour or so.
- somethingcleve5Aspirant
I should note I've done the reset multiple times on both devices. Since it is happening with both units in both homes there is no question it is the netgear modem/router that is the issue. I've also seen multiple discussion posts with this same issue and none have been resolved.
- LALINAspirant
IM HAVING THE SAME PROBLEM WITH THE SAME UNIT EVERYDAY.
It's crashed in the neighborhood of 20-25 times today. It's the biggest pos I've ever purchased, and that includes my first car, which was 10 years old. I am going to go on a crusade to warn people. It's beyond annoying.
- DarrenMSr. NETGEAR Moderator
Hello somethingcleve5 and LALIN
I would contact Netgear support if the modem is still under warranty they will be able to do some troubleshooting with you and replace the modem if they find it defective.
http://www.netgear.com/support/contact.aspx
DarrenM
