rhill1959's avatar
rhill1959
dropping wifi
Hi,
I'll start out by saying I don't know much about wifi or networking.  My problem is wifi connected devices will stop working.  For example on the iphone it stops working, I'll try the other wifi frequency and it might work, but most times it doesn't .  Sometimes rebooting the iphone fixes it, and other times I end up having to reboot the router taking other attached devices down.  Before doing that, I'll ask around the house and some systems are fine while others may have a problem.
If I go into the admin page for the router and look at the connected devices page, it will have pages of them.  I'll do a refresh and it will narrow down the actual list.
Any ideas what the problem is and how to correct this problem?
Model:  C7800
Firmware:  V3.01.40
Thanks,
Robert Hill
  • FURRYe38's avatar
    https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
    • rhill1959's avatar
      rhill1959
      Thanks for the pointers.  I did the channel changes for both 2.4 and 5 ghz.  I checked my advanced settings > wireless settings.  Implicit Beamforming was already on, and I don't have options for either MIMO or WMM.
