tweeetycrazee's avatar
Jul 10, 2022
echo dot plugs and lights
I restarted my modem and now I can no longer connect to the echo plugs and lights.  It still connects to the echo dot itself.  Thinking on this.. I can no longer connect to my printer wirelessly.  Please help?  Thank you in advance.
  • FURRYe38's avatar
    You gave us nothing to go off.
    What NG product are you referring too?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
  • It would also be helpful to know what brand and model number of smart plug you are using.
