StarboardBow
Jul 04, 2017Star
embedded web interface fails after week runtime
Have C3700-100NAS, currently running firmware V2.02.08 upgraded thru Comcast xFinity ISP. Can normally connect to unit's embedded web interface both thru default IP 192.168.0.1 and URL http://rou...
StarboardBow
Jul 24, 2017Star
Received response from Netgear Support (Netgear Support Case #28684210) stating the following:
"Our engineers seem to be able to find the cause of this issue. They will release a firmware to fix it. However, it is going to take a while before it will be released to Xfinity end users."
Ricardo
Expert ID: 8315
NETGEAR L2 Support Expert
Also, received followup response to followup inquiry as to timeframe when firmware fix can be expected to be released stating the following:
"Thank you for responding. I cant really provide an ETA on when our engineers will release the new firmware. Once the provide it to your ISP, the ISP will run another test before they will push the firmware to the modem/routers."
John
Expert ID: 8312
