tomham's avatar
tomham
Guide
Nov 25, 2020
erratic speeds with CM 500 Cable Modem
Hi just purchased a CM 500 cable modem for my daughter.  Comcast had trouble "finding it" but did eventually.  But I noted very erratic up & down load speeds.: 168 Mbps to 1.2 download and 2.5 to near zero download; it goes all over the place. Comast put in a new "drop" form the street pedistal to her home entry; said the signal was strong.
Are there any "tweaks" to the modem or any other suggestions to get the speed to be high consistantly?  (her service is "up to 300 Mbps", so I'd be happy with any where near 150 or so.
Thanks for any assistance.
  • I have found the problem (after hours tracing down the wiring).  The problem is / was with the splitter / amplifier.  It was difficult to find because I did not install it and the wiring was (shall I say) not direct or obvious.
    My Thanks to Net Gear & the knowledgeable folks here.  Knowing that the modem was fine and the irratic connection helped isolate the problem.
    Case closed & Thanks.
  • plemans's avatar
    do you have a screen snip of the cable connections page and the logs?
    Those help us check the connection.
    If you have any splitters, amplifiers, or attenuators in the coax line, I'd remove them. Check the line for kinks, damage, bad/cheap/loose connectors.
    • tomham's avatar
      tomham
      Guide
      Thanks for the rapid reply.
      The download signal for all 16 channels range from 4.3 dbmv to 5.0, so that looks pretty good I think.
      The upload signal for all 4 channels range from 40.5 dbmv to 42.5, again that looks pretty good.
      My speed ranges from 1.2 Mbps to 23.5 to (at times) with 168.3 rarely (download).  Upload ranges from 0 to 1.2 Mbps.  All with a service of "up to" 300 Mbps; so something is drastically wrong here.   :)
      I'm having a Comcast tech come out on Saturday to take a look at, but if I'm getting those signal levels it sounds like the issue is not with the modem, but let me know your thoughts.  I'll post what I find out.   Thanks again.
      • plemans's avatar
        The download signal for all 16 channels range from 4.3 dbmv to 5.0, so that looks pretty good I think.-------a screen snip would be better than "i think"
        My speed ranges from 1.2 Mbps to 23.5 to (at times) with 168.3 rarely (download).  Upload ranges from 0 to 1.2 Mbps.  All with a service of "up to" 300 Mbps; so something is drastically wrong here.   :)----Thats where the logs and the cable connection page helps.
