RobMHTown
Mar 08, 2019Follower
Ethernet Port Issue
Hi All - so I have an interesting issue. I have a CM1000 cable modem, Gig internet via Xfinity. I use a Linksys Velop system and have a Netgear GS316 unmanaged switch which feeds interenet into ...
antinode
Mar 08, 2019Guru
> I had initially thought this was a poor cable somewhere [...]
You may have been right.
> [...] However, [...]
Any hardware change could affect some marginal condition in other
hardware -- flakey cable, weak receiver/transmitter, ... One device
might erroneously negotiate a 1000MHz link, and then fail when it tries
actual communication at that speed, while another device might fail to
negotiate a 1000MHz link, and then work better at a lower speed.
> [...] Connection speed is ~90mbps which is below the gig speed, [...]
Gigabit speed uses all four pairs in a cable; slower speeds use only
two. On the Mac, System Preferences > Network : Ethernet <n> >
Advanced... : Hardware should tell you the physical link speed.
> [...] trying to figure out how to access via the switch only (no AP
> between device and switch).
I'd try to move the computer to within range of a known-good cable,
and, if that works, then start adding questionable hardware until the
failure (re)appears.
I recently spent far too much time on the phone with a friend whose
Windows system seemed to be confused about the existence of his
Ethernet/Internet connection. LEDs were flashing happily everywhere,
but the Internet was always out of reach. In desperation, he hauled the
computer to within different-cable-range of the network switch, swapped
cables, and every ill was instantly cured.
