ftlu
Feb 16, 2016Follower
Ethernet switch for C3700
I bought a smart switch (tplink TL-SG1016DE) for wired access, wired devices worked as expected but wireless devices could not access internet when the switch is plugged into C3700. Unplugged the switch from C3700 and everything worked as before. BTW, I do use a TP-Link N300 range extender for part of the house that wireless signal is very weak.
Can anybody suggest a good 16-port switch that will work with C3700?
thanks
1 Reply
- netwrksMaster
TPLINK default Ip address is: 192.168.0.1. Your router's default IP address is also: 192.168.0.1. (unless you changed the default subnet). That would be a conflict..
http://www.tp-link.com/resources/document/TL-SG1024DE_V1_User_Guide_1910010980.pdf - Page 6.
