LowGeared1
Feb 23, 2018Aspirant
Ethernet switch or hub or ???
Dumb question? This system forced me to enter a model so I did but I lied as I don't have a model. I have 2 ethernet devices and my router has one available ethernet port. I'm looking for a device...
antinode
Feb 23, 2018Guru
> Dumb question?
No, but describing your equipment as "my router" is less than
helpful.
> port.
What, exactly, is your "my router"? Define "available". How many
Ethernet ports does it have, in total?
> [...] Is what I'm looking to do even possible?
That may depend on exactly what your "my router" is. If your "my
router" really is a router, then you should be able to use an Ethernet
switch (or hub) to expand the number of available ports.
If your "my router" really is a modem (only, not a router), then you
should probably add a router rather than a switch.
Nowadays, an Ethernet hub is gettng hard to find. An Ethernet switch
costs about the same, and performs better in most cases.
> [...] Ideally the device would come with a remote control so I could
> sit on my fat rear and do the switching from the couch. But it's O.K.
> if I have to get up and push a switch in order to make the connection.
No, _ideally_, the device would let you connect mutiple devices at
the same time, and not make you worry about which one is connected. A
router, perhaps with a switch, should do that. The only mystery is what
you already have, which would affect what you should get.
