LowGeared1
Feb 23, 2018Aspirant
Ethernet switch or hub or ???
Dumb question? This system forced me to enter a model so I did but I lied as I don't have a model. I have 2 ethernet devices and my router has one available ethernet port. I'm looking for a device...
LowGeared1
Feb 24, 2018Aspirant
Thanks for the info. Obviously I know so little about this that I don't know what information I should be providing.
The system in question is from Charter Spectrum and consists of a Cisco DPC3216 modem and a Sagemcom Fast 5260 router.
In addition to being wireless, the router has 4 ethernet ports.
The uses I have for the one remaining unused port are 1) for a computer that's used for doing things like watching YouTube or other videos that are available on the internet. 2) a Sony blue-ray device. Every now and then we want to use the Sony to connect to Amazon prime videos.
I can't envision ever wanting the 2 devices to be operating at the same time.
The output of these devices goes to our TV via an HDML switch (Octava UHD41-ARC).
Thanks again.
antinode
Feb 24, 2018Guru
> [...] and a Sagemcom Fast 5260 router.
Ok. It's a router.
> [...] If your "my router" really is a router, then you should be able
> to use an Ethernet switch (or hub) to expand the number of available
> ports.
Still true. Invest the $20 or so in a 5- or 8-port gigabit Ethernet
switch. Connect one of its ports to "the one remaining unused port" on
the router. Bask in the luxury of the remaining ports on your new
gigabit Ethernet switch.
> same time.
Doesn't matter. If you ever did find anything which would do what
you had in mind (some kind of Ethernet A-B switch), then it'd probably
cost more than the right thing, a (hub-like) gigabit Ethernet switch.
The fact that there isn't even a good name for what you wanted should be
a clue. "Ethernet switch" is already in use for what you should have
wanted.
A Web search for "difference between Ethernet hub and switch" should
explain that, if you're interested.
> UHD41-ARC).
"HDMI"? That's a different problem.
