dcarey1964's avatar
dcarey1964
Event log CM 1000
Is there anyone the can look over my event logs and give me so insite on why it keeps going down 2 or 3 times a day. Cox support says it's my equipment.
  • plemans's avatar
    Do you also have a screen snip of the cable connections page? it helps to have them both to compare.
    many of your errors/warnings are related to signal issues. That's where that cable connections page can help.
    if you have any splitters, attenuators, or amplifiers in line, remove them.
    • dcarey1964's avatar
      dcarey1964
      i do have a splitter and i downloaded the cable connection log
      • plemans's avatar
        you also need the upstream info. and ofdma
