Venky1
Dec 14, 2025Follower
Every month I have to reconfigure the CAX80
Mine is different; every month, the CAX80 internet connection must stop, and then will require a password change. I have been having the same problem for 4 months. Every month I have to reconfigure ...
Dec 14, 2025Guru - Experienced User
I've got a CAX and never had that issue.
- what firmware are you on?
- why does it require a change?
- Have you tried reinstalling the firmware, doing a full factory reset (push and hold reset for 15 seconds while powered on), and then a reinstall? maybe something is corrupt in the firmware causing it to need the change.
