husam
Dec 03, 2016Aspirant
Factory Default Reset is MESSED UP on N450 CG3000Dv2
I was using my N450 with Time Warner, then switched so I decided to sell it. I tried resetting it to factory default, but when it finished, the result was a completely different SSID than the one pr...
TheEther
Dec 03, 2016Guru
Factory resetting most Netgear usually involves pushing and holding the reset button for about 8 to 10 seconds until the lights flash on and off.
If this doesn't work, then just log into the router and manually change the SSID.
