brettdotcom14
Dec 19, 2021Aspirant
factory reset after power failure CAX80 RAX50
every time i have a power failure my cax80 loses my cable company info as well as my admin login security question and any other settings. same goes for my rax50 which i only have setup as an access ...
brettdotcom14
May 10, 2022Aspirant
Unfortunately No still happening to this day anytime I lose power. I’m probably going to have to contact Netgear. Not that I lose power that often but it’s a bit annoying having to do to both of them every time.
May 10, 2022Guru - Experienced User
Have you tried newer FW yet?
If you have, I recommend downloading this to a wired PC first, Use MS Edge or Firefox to load the FW. After the CAX 80 is back online, press the reset button for 10 seconds or I prefer the ERASE button under Advanced Tab/Advanced Settings/Backup. Set the CAX up from scratch, then see if it still happens.
- brettdotcom14May 10, 2022AspirantI will give that a try. I know I had the app check for new firmwares but they said they were up to date. Appreciate the help and info
- FURRYe38May 10, 2022Guru - Experienced User
NG may not put new FW updates on there auto update services so the modem or NH app may not catch anything. I try to post new stuff here in the forums as I see it come out or gets posted from NG.
