jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 03, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
ElaineM
Nov 03, 2015NETGEAR Employee Retired
vnktsn Glad to hear that it's up and running!
Thank you for the update.
NoMoreN600 If you happen to have the Genie App installed, under WiFi Connection > WiFi Channel you'll see all devices connected to different channels.This window also shows what channels are being used by your neighbor. Select the best channel that have less users in it. For example, below I can select channel 4. You might be wondering about channels 12 and 13, these channels are only available in some countries. But if you're in the US you can only have 1-11 channels. You can easily change channel by clicking Change Channel at the right hand side of that window and then Modify the channel.
NoMoreN600
Nov 04, 2015Aspirant
Thank you for the info. I had installed the Genie program on my laptop but hadn't explored it. Definately a good feature to include!
