jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
yourworstfears
Nov 25, 2015Aspirant
im also having the same issue with my WNDR3400v3. but i think its a comcast issue becuase i used to have thier gateways that they provided and had the same issues with wired speeds being good but wifi being very slow. i had blast wich back then it was 50mbps and i got around 60mbps wired and around the 20smbps on wifi. they told me that thier gateways were crap and told me to buy my own modem and router. once i moved to a new apartment i got comcast and bought my own equipment i used to have the performance internet which was 25mbps. i was very happy with my router that i got 25mbps on wifi and on wired i get 30mbps. now i upgraded my service to blast which is 75mbps and i did a speedtest with wired and got 88mbps. but on wifi my highest is 29mbps. thats a huge difference is thier anything i can do to fix this issue.
this is the bug comcast has http://www.dd-wrt.com/phpBB2/viewtopic.php?t=176395&postdays=0&postorder=asc&start=0
