jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
yourworstfears
Nov 30, 2015Aspirant
I think it's a xfinity issue because I had this same problem with their gateways that they provide.
- ElaineMDec 01, 2015NETGEAR Employee Retired
8Ohms What's the model and OS of the device you're having an issue? What's the model of the LAN/Wireless adapter being used and its driver version?
Can you post a screenshot of inSSIDer showing the 2.4Ghz environment? What's the distance between the C3000 and the client being used?
- RxrepDec 01, 2015Aspirant
Same issue. LAN speeds out of WNDR4300 are stable at @30mbps download and 6-10 upload on Xfinity via their modem cabled to WNDR4300. Even after leaving only one wireless device hooked up (HP running windows 7), repositioning router, and doing all of the tweaks I've read in this thread, i can't get anything faster than 3mbpsD and 1mbpsU. This only started happening in the last month. Prior to that my wireless matched my LAN speeds. What gives?
