jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 03, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
pdrupareliya
Jan 21, 2016Aspirant
I have exactly the same issue. Got a 100mbps speed connection and get that on any device if connected by LAN with the router . But on wifi I get only 50 mbps on the 2.4 ghz . On the 5 ghz I get slightly better speeds (60-70) but that in turns makes the wifi signals drop with the extenders I have (also netgear). So the technician dialed the 5ghz . Still not getting above 60mbps from the wifi.
- ElaineMJan 22, 2016NETGEAR Employee Retired
pdrupareliya What's the model number of your NETGEAR device?
2.4GHz is really prone to interference and that might be the reason why you're getting that speed.
Wired can't be the same as the wireless speed. These 2 are totally different connections and there are factors that needs to be considered when it comes to wireless.
