jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
mohan5k
Jul 18, 2016Aspirant
I have the same issue. When connected to Arris modem? Any solutions pls let me knkw
ElaineM
Jul 19, 2016NETGEAR Employee Retired
mohan5k What's the exact model number of your device?
What's the firmware version installed?
All devices are affected?
What are the devices affected?
Kindly describe further on what you're experiencing so we can provide better response.
- aussiedogJul 23, 2016Aspirant
Wired connection directly to modem: 180 mbs (comcast)
Wired connection through router: 20 mbs
Wireless connection using router: 20 mbs
Same issue with all devices
Not a cable issue for the wired connection (tried several)
no interferences from other devices (and of course, this wouldn't explain the wired slow connection)
on latest firmware
did the 30-30-30 that briefly improved the WIRED connection only, but minutes later it reverted to 20 mbs
The router clearly seems to be a bottleneck, and it is not just a wifi issue. Any solutions short of getting a new router?
- ElaineMJul 25, 2016NETGEAR Employee Retired
This should have been corrected by a firmware upgrade and reset.
Since you're still experiencing the same thing, I suggest that you get a new router.
