jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
jrp1311
Sep 16, 2016Aspirant
Hi folks. I'm having the same problem on my C3700. Ethernet speed is fast, wifi speed is a lot slower. If the issue is that it is not tested or 3 starred with Comcast, does anyone know of a wifi/modem combo that is and will work with Comcast?
