jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
saneopinion
May 13, 2017Initiate
Guys.. don't waste your time troubling shooting this... It's a router issue.. here is the solution... disable Wi-Fi on your modem .. buy a cheap $15-20$ router ..connect that to the modem via lan wire and use this new router to connect to wifi. It worked for me and another person on this forum
