jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
jkeats
Mar 20, 2015Novice
I tried that and it didn't do much. I was able to move some devices around and got the 5ghz speed up to 75-80mbps (again, standing right in front of the router) but the 2ghz is still in the 30-45mbps range.
This is off a 200mbps download speed (which I do get on my wired PC).
What would be realistic to expect as a speed testing at a close distance. It seems like 50% would be about right but I'm not sure.
- carl321Sep 04, 2015Star
2.4Ghz cant give you speeds over 54Mbps
use 5Ghz for speeds over 100Mbps but will only go upto 300Mbps
its how they work
- 8OhmsNov 21, 2015Guide
Good point. How do you make the switch? Cold you please explain the procrdure?
- ElaineMNov 23, 2015NETGEAR Employee Retired
NoMoreN600 Let us know any update.
8Ohms Have you tried the other suggestions?
Can you let us know more information of the problem you're facing?
