jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
ricmanning
Apr 14, 2015Novice
I have the same problem. I get 20mbps service from cable. Ookla clocks 20 on my PC, which is connected by Ethernet cable. All WiFi devices clock at about 5 mbps. I have three home WiFi networks available: Standard, 5G and one labelled _EXT for the Netgear extender I use on the second floor. What's the bottleneck? And how can I fix it?
