jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
jkeats
Mar 20, 2015Novice
I tried that and it didn't do much. I was able to move some devices around and got the 5ghz speed up to 75-80mbps (again, standing right in front of the router) but the 2ghz is still in the 30-45mbps range.
This is off a 200mbps download speed (which I do get on my wired PC).
What would be realistic to expect as a speed testing at a close distance. It seems like 50% would be about right but I'm not sure.
carl321
Sep 04, 2015Star
2.4Ghz cant give you speeds over 54Mbps
use 5Ghz for speeds over 100Mbps but will only go upto 300Mbps
its how they work
- 8OhmsNov 21, 2015Guide
Good point. How do you make the switch? Cold you please explain the procrdure?
- ElaineMNov 23, 2015NETGEAR Employee Retired
NoMoreN600 Let us know any update.
8Ohms Have you tried the other suggestions?
Can you let us know more information of the problem you're facing?
- 8OhmsNov 23, 2015Guide
Hello Elaine,
I contacted Netgear and the support technician had me changes a few settings using the Netgear Genie. At first the speed was slower when I ran the test using speedtest. The support technician told me was going to check with his collegue and never came back to me or returned my call after an hour. Here's the issue. I am with Xfinity/Comcast. When my new C3000 Netgear Router/Modem is connected with with the wire. The speed is phenomenally fast. I am getting over 90 Mbps consistently. THen when I unplug the wire and go wireless. The speed on IPv4 range between 22 to 29 Mbph, and between 33 to 39 Mbps on IPv6. Those are less than half the speed I get using on the LAN with the wire connected. So I wanted to know if this was normal for the C3000 and for my region. I was told that I should be getting at least half the LAN speed or more by the Netgear support technician. Since that call to Netgear. I have not changed any of the settings, and I am still getting less than half the speed of the LAN on the wireless, even when I take the speed measurement with my PC within arms reach of the Router/Modem.
So if anyone here has had this issue, and managed to find the right settings for increasing the speed of the download to at least half of what I get using the wired connection. It would be greatly appreciated if you would share the information in details.
Thanks
