jkeats
Mar 19, 2015Novice
Fast LAN speed/slow WiFi speeds
I sent in a ticket to support on this but still haven't come up with a solution so I thought maybe some forum users might have an idea... I've got the WNDR4300 with the latest firmware. I use an A...
- Nov 02, 2015
Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
ElaineM
Oct 29, 2015NETGEAR Employee Retired
NoMoreN600 Do you have the same exact model number and version of the router?
Can you post a screenshot of the speedtest?
What are the wireless clients used?
Which signal you're connecting to (2.4Ghz or 5Ghz)?
vnktsn
Oct 31, 2015Aspirant
I too have the same issue - wndr4300 + Aaris 6183 modem. Thru Lan shows 90MBPS, but wireless is very fluctuating 25 - 30 MBPS. Sometimes it is going doing upto 10 MBPS.
