SimpleUser
Mar 07, 2016Tutor
firmware update c6300 ac1750
It seems Netgear sold me a cable modem that can only be updated by an ISP. Of course, my ISP (TWC) will not update the firmware because it is not their equipment. So, I figure I will try to return th...
bearilla83
Sep 24, 2016Aspirant
Im haaving issues with my modem like the others. I am on cox cable how do I fix my issue?
KayK
Sep 26, 2016Tutor
Are you on the old firmware (v.1). Definitely worth getting up-graded to v.2. The issues I had completley disappreaded after the up-grade (connectivity speed also increased).
Again, I recommend to chat because it's less frustrating and generally saves time.
Ka
