SimpleUser
Mar 07, 2016Tutor
firmware update c6300 ac1750
It seems Netgear sold me a cable modem that can only be updated by an ISP. Of course, my ISP (TWC) will not update the firmware because it is not their equipment. So, I figure I will try to return th...
Cmakar
Oct 03, 2016Aspirant
Changing the signal doesn't help and also using auto channel does the same thing.. the problem is that is just stops responding and the only fix is to power it off and back on. Anyone know if TWC is going to be pushing these new firmwares?
