yahx
Aug 12, 2017Follower
Frequency Start Value - N600 WiFi Cable Modem Router
I've tried contacting my ISP (Comcast/Xfinity) and Netgear, both have not been very helpful. My internet is sluggish and constant drops connection both on wired and wireless devices. Could you please help me identify the issue? Please let me know what data I can provide to help it trying to resolve this. I think it might have to do with the frequency start value:
| Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Current System Time:Sat Aug 12 17:21:57 2017 |
I'm trying to identify if this is a hard ware or software issue.
Thanks!
1 Reply
- DarrenMSr. NETGEAR Moderator
There is a lot of uncorrectables happening on channel 8 could be some type of connection issues happening. Do you have any splitters connected to the modem? have you tried to remove them?
DarrenM
