Prim
Jan 02, 2019Aspirant
Fs608 v2 - 8 Ports: How to connect to DsL Modem
Hello,
I've got a FS608 v2 Fast ethernet swicth from my friend. But i don't know how to connect this
to the DSL Modem. Which Port do i use for the ethernet cable that comes from the DSL moden...
antinode
Jan 02, 2019Guru
> [...] I have connected the Modem to a edimax router.
Yow. Did you really think that "a edimax router" was a useful
description of anything?
> [...] The name of the modem is Draytek Vigor 2132.
Plain "2132", not "2132xxx"? To me, that looks like a router, not a
modem, and not a simple switch:
http://www.draytek.com/ftp/Vigor2132/Manual/DrayTek_QS_Vigor2132-Series_V1.2.pdf
> So, What you're saying is that i can't connect the draytek to the
> FS608 switch?
What I said was that connecting a modem to a switch would probably be
a mistake. But your "the Modem" seems to be a router, so connecting a
switch to one of its LAN ports should be fine. Except that a "Vigor2132
Series Security Giga Router" would seem to have gigabit Ethernet ports,
so that a "Fast" Ethernet switch could add a new bottleneck to your
network.
If you ever decide to reveal what your equipment actually is, and how
all of it is connected, then it might be possible to stop guessing, and
make some actual progress. (I won't hold my breath.)
Prim
Hi Thanks for reply and patience. I'm going to by a new switch/router.
- antinodeJan 02, 2019Guru
> [...] I'm going to by a new switch/router.
To replace what? What's wrong with the DrayTek whatever-it-is?
Still a mystery.
If you can't tell a modem from a router from a switch, then you might
want to sort that out before you start shopping for new gizmos which may
or may not do anything useful for you.
