pablocarc's avatar
pablocarc
Genie password
I forgot the Genie password. (not the wifi router password, just the Gennie software on my computer). How do I get it back or replace the password ?
  • Hi pablocarc
    If you can not logged in using the default password or you forgot the password then you are probably going to have to reset your router to its default settings.
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi pablocarc
    Welcome to NETGEAR Community!
    May we please know the model number of your NETGEAR device?
    Blanca
    Community Team
      • Blanca_O's avatar
        Blanca_O
        Hi pablocarc
        Blanca
        Community Team
