RL9257
Jul 23, 2016Aspirant
GS108v4 replace power adapter
I need to replace a power adapter for my NETGEAR ProSAFE GS108 8-Port Gigabit Desktop Switch (GS108-400NAS). My cat ate the cord :-(. I am seeing model number as AD2015F23 but cannot find that part a...
VE6CGX
Jul 23, 2016Master
Which cord? Input side or outpust ide? If it is just damaged, you can repair the damage, most likely by splicing two wires. If it is output side ,
make sure splice the wires exactly identical one. Being DC it is polarized. Usually one wire has a white strip or rib which is (-) side. Or if
you want a replacement one with same or better specs will do. Just make sure the polarity of the output conenecter. Netgear does not
make adapters, Amazon or eBy will have plenty of choices. I bet you could even find a exact replacement.
