Philsaywas's avatar
Philsaywas
GS308P-100UKS replacement PSU
does anyone know how to get hold of a replacement PSU for a GS308P-100UKS POE switch
  • I think these switches have a lifetime warranty.
    Request an RMA via NetGear.
    Login otr create a NetGear account if you haven't already.
    Then proceed accordingly.
    • Philsaywas's avatar
      Philsaywas
      the PSU is water damaged due to its old location, now in a weather proof box
      • additude's avatar
        additude
        Virtuoso
        I Googled it and came up with several options.
        But you would need something for the UK, right?
        GS380P-100UKS
        Any power supply that meets or exceeds the voltage and current requirements and has the same size barrel plug will work as a substitute.
        Power requirements should be Stamped/Molded/Stickered close to the connector jack.
        It looks like the barrel plug is the 5.2mm size....
        What I found were conflicting output voltages so I can't say it's 5v, 12v or 48v .....
        Sorry that I couldn't help further....
