DRONDEAU
Sep 15, 2025Aspirant
Hardwired connections are fine. WiFi bounces up and down
My CAX80 has the same issue. hardwired connections are fine. WiFi bounces up and down. I tired to change a variety of settings but the save default back to factory. Is there a physical jumper and swi...
Sep 15, 2025Guru - Experienced User
How is the wifi radios configured on the gateway?
Is Smart Connect enabled?
Is Protection Engine enabled?
