DRONDEAU
Sep 15, 2025Aspirant
Hardwired connections are fine. WiFi bounces up and down
My CAX80 has the same issue. hardwired connections are fine. WiFi bounces up and down. I tired to change a variety of settings but the save default back to factory. Is there a physical jumper and swi...
DRONDEAU
Sep 23, 2025Aspirant
I connected online to the Xfinity support line again. I ended up doing a soft reboot. I reset the button on top rear of the router. the WiFi works fine now. But since Xfinity was guiding me, the question comes up "did they do some type of reset or parameter change on the router remotely?".
Sep 23, 2025Guru - Experienced User
How is the wifi radios configured on the gateway?
Is Smart Connect enabled?
Is Protection Engine enabled?
ISPs can only effect the modem side of the gateway.
