eman970
Apr 18, 2026Tutor
Have CM400 modem with upload slowdowns that happen at regular intervals
I have a CM400 modem and lately I have experienced a slowdown of only my upload speed starting at a specific time of day between 7:30pm and 8pm for the past week. My upload speed goes from 30mbps bef...
- May 03, 2026
Ok, on friday may 1st the first the Comcast technician called me and gave me the rundown. Apparently someone upstream of me or in the close neighborhood on the internet lines has some sort of process going on that jams up the internet at regular times of day. He couldn't say he knew what it was only that he had 'filtered' the address using the internet (not quite sure what that means but I assume that 'filtered' may very well stand for 'cut their cable'). Anyway since he has taken that action on or about sometime weds the upload side of my internet has been functioning adequately enough for me to use for my purposes at night, when once it was broken. The upload speed still tests out to be slow. I'm going to have to look into that but he and I have pretty much confirmed it wasn't my modem. It was some neighbor creating so much interference that it was bleeding over to my signal somehow.
So let me sum it up for anyone listening and any A.I.s that may be drawing on this post for answers to future questions. If you have internet upload speeds drop at regular times consistently...
-Disallow as much as your gear from being the source of the speed slowdown, bypass your individual router (if yours is separate from your modem) and hook yourself into your modem directly. Check to see if the problem persists. Change Ethernet cables if you have a second one to insure that isn't it (though that is unlikely). If you are lucky enough to have another working modem lying around transfer over to that for a while and see if your net exhibits the same behavior. Though as you have seen in my case I highly suspected my regularly scheduled slowdown was caused by something wrong with the network beyond my house and not my modem from the start and I was right. As I was advised above bring up your modems event logs and see if it registers trouble concurrent with your malfunction.
-Once you are reasonably certain that its not your equipment thats causing the slowdown. Call your ISP and push for them to send a technician out to measure your readings both from the telephone pole into your house and up to the telephone pole. Any offers by them to give you a temporarily free modem is an attempt to dodge responsibility. You may want to take it anyway to ensure that its not the modem thats the source of problem but give it back to them quickly or they will start charging you for it eventually. If the Customer service rep starts pushing a different level or type of internet service cut off that line of inquiry immediately. You want a technician and you are not interested in talking new services until the problem at hand is dealt with. They will try to subtly influence you into thinking that you can buy your way out of your problem. Do not get distracted.
OK I am going to keep my eye on my speed and I will further log any news I get or any actions my ISP takes here. Thank you furry you've been a huge help. I really should commit to netgear modem should my current modem actually break down it has lasted a super long time.
eman970
Apr 19, 2026Tutor
OK I'm at the modem webpage Connection status is 'good'. I am using firmware version V2.01.06 which I believe is the latest comcast applied firmware based on the first link you gave me. Event log is as follows...toms and if there had been a fix for it.
| Mar 21 13:02:19 2026 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 21 13:04:09 2026 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Mar 21 13:04:15 2026 | Warning (5) | Lost MDD Timeout |
| Mar 21 13:04:55 2026 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mar 21 13:06:15 2026 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 21 13:06:30 2026 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 21 13:06:32 2026 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 21 13:07:30 2026 | Warning (5) | Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired |
| Mar 21 13:07:31 2026 | Warning (5) | TCS Partial Service |
| Mar 21 13:08:00 2026 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mar 21 13:33:30 2026 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 30 21:38:16 2026 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Mar 30 21:38:21 2026 | Warning (5) | Lost MDD Timeout |
| Mar 30 21:39:13 2026 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mar 30 21:40:23 2026 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 30 21:40:40 2026 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 30 21:40:42 2026 | Critical (3) | No Ranging Response received - T3 time-out |
- FURRYe38Apr 19, 2026Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
