MisFiTkEv's avatar
Feb 13, 2021
HELP!!! cm1200 + RAX80 + Spectrum [Frequent Disconnects]
Please help.  I keep having internet connection issues---frequent disconnects causing me to have to reboot.  This has been happning to months.  Ive had 4 Spectrum people out here --- they have reinstalled the cable from the poll (to eliminate noise as a problem). I am getting so desperate.
I have tried so many things---any advice...or assistance you can give would be much appreciated.  Ive seen the "Spectrum wont update firmware" thread---- but, is there anything else I can do?
Below are my stats: (keep in mind, I just rebooted---but for the most part I get the following errors):
Started Unicast Maintenance Ranging - No Response received - T3 time-out
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Modem CM1200 [Firmware V1.02.01)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25633747000000 Hz5.4 dBmV39 dB90
2LockedQAM2561453000000 Hz7.9 dBmV41.2 dB00
3LockedQAM2562459000000 Hz7.8 dBmV41.1 dB00
4LockedQAM2563465000000 Hz7.7 dBmV41 dB00
5LockedQAM2565477000000 Hz7.6 dBmV40.3 dB00
6LockedQAM2566483000000 Hz7.4 dBmV40.8 dB00
7LockedQAM2567489000000 Hz7.4 dBmV40.8 dB00
8LockedQAM2568495000000 Hz7.4 dBmV40.9 dB00
9LockedQAM2569507000000 Hz7.5 dBmV40.8 dB00
10LockedQAM25610513000000 Hz7.6 dBmV40.8 dB00
11LockedQAM25611519000000 Hz7.5 dBmV40.7 dB10
12LockedQAM25612525000000 Hz7.3 dBmV40.6 dB00
13LockedQAM25613633000000 Hz6.1 dBmV39.8 dB100
14LockedQAM25614639000000 Hz6 dBmV39.8 dB180
15LockedQAM25615645000000 Hz6.1 dBmV39.9 dB80
16LockedQAM25616651000000 Hz5.9 dBmV39.7 dB160
17LockedQAM25617657000000 Hz6 dBmV39.7 dB90
18LockedQAM25618663000000 Hz6.2 dBmV39.7 dB170
19LockedQAM25619669000000 Hz6.3 dBmV39.6 dB170
20LockedQAM25620675000000 Hz6.6 dBmV39.3 dB160
21LockedQAM25621681000000 Hz6.8 dBmV39.6 dB190
22LockedQAM25622687000000 Hz6.9 dBmV39.6 dB180
23LockedQAM25623693000000 Hz6.7 dBmV39.7 dB120
24LockedQAM25624699000000 Hz6.5 dBmV39.6 dB150
25LockedQAM25626705000000 Hz6.4 dBmV39.6 dB140
26LockedQAM25627711000000 Hz6.4 dBmV39.5 dB110
27LockedQAM25628717000000 Hz6.4 dBmV39.5 dB80
28LockedQAM25629723000000 Hz6.1 dBmV39.2 dB230
29LockedQAM25630729000000 Hz5.9 dBmV39.2 dB190
30LockedQAM25631735000000 Hz5.5 dBmV39 dB110
31LockedQAM25632741000000 Hz5.4 dBmV39.1 dB60
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA495120 Ksym/sec17800000 Hz44 dBmV
2LockedATDMA505120 Ksym/sec24200000 Hz43.8 dBmV
3LockedATDMA515120 Ksym/sec30600000 Hz43.3 dBmV
4LockedATDMA525120 Ksym/sec37000000 Hz43.3 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock
Status
Modulation /
Profile ID
Channel
ID
FrequencyPowerSNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,225266000000 Hz6.1 dBmV41.3 dB148 ~ 394779006097742644680
2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked000 Hz0 dBmV
CM1200 EVENT LOGS
TimePriorityDescription
Sat Feb 13 12:21:08 2021Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:01:5c:7a:e8:58;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 13 12:21:03 2021Notice (6)TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:01:5c:7a:e8:58;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 13 12:21:03 2021Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:01:5c:7a:e8:58;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 13 12:21:03 2021Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:01:5c:7a:e8:58;CM-QOS=1.1;CM-VER=3.1;
Sat Feb 13 12:21:03 2021Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:01:5c:7a:e8:58;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv4
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:01:5c:7a:e8:58;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3d:8d:80;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
RAX80 CONNECTION STATISTICS (Firmware V1.0.3.106_1.0.50):
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WAN1000M/Full872706366598101712473693501:37:08
LAN1Link Down------------
LAN2100M/Full38027183108002701:36:54
LAN3Link Down------------
LAN4100M/Full102559851182202221502029101:36:53
LAN5100M/Full38855321108339501:36:54
2.4G WLAN b/g/n/ax1200M52184262040108481101:37:35
5G WLAN a/n/ac/ax4800M243805263499805848801606701:37:35
1 Reply
